Hello all! I think this is the right category, sorry if I got it wrong.
In short: RC_CHANNELS
in mavlink data shows no response to transmitter inputs. but I know a signal is being received by the Navio since I can see a response to transmitter input (throttle) here:
# high
pi@navio:~ $ cat /sys/kernel/rcio/rcin/ch2
2006
# low
990
# middle
1549
So the signal is getting to the board and to the CPU. but, RC_CHANNELS
and RC_CHANNELS_RAW
don’t move at all:
I’ve been all over the Arducopter documentation, especially this page, which says:
For all protocols above, ArduPilot auto-detects the protocol of the RC receiver system.
Makes it sound like this should “just work,” although I wouldn’t be surprised if there were a parameter I had to set somewhere.
Protocol in use: SBUS. Failsafe: No Pulses. Rate: F1000 (-104dBm)
FC: Navio2 with RPi 3B as companion. Have followed the simple setup directions here and here
This happened in arducopter 4.0.3, and continues to happen after upgrade to v4.5.1.
Any thoughts? Is there a broken link between the /sys/*
file descriptors and whatever Arducopter is reading from? Is there a config value to set somewhere, or a debug log to look at to figure out where the SBUS input is getting lost? Where does Arducopter read RC input from, if not these file descriptors?
Thanks!
