I need some assistance with the steering of my boat. The boat is weaving (Moving like a snake in the water) in RTL and Auto. I played around with the following settings NAVL1_DAMPING: 0.75 0.61.0 and NAVL1_PERIOD: 20 s 1 60 but to no avail.
Products used:
FC: APM 2.6
Receiver: TBS Crossfire full version
Remote: FrSky X9D Plus
Hi David,
Very difficult for me to add the logs, I am working on a Mac.
I quickly went through some of the older threads and could see that most people made their steering adjustments on the “Basic Tuning” screen where they have changed the “Steering Rate PID” settings. After that, they would go to the “Full Parameter List” and make a minor adjustment to “NAVL1_PERIOD” & “NAVL1_DAMPING”
One last question, what does ATC_STR_RAT_FF stands for and where do I find them, will I also find them in the “Full Parameter List”?
You say you are using an APM 2.6. What version of the code do you have loaded? I don’t remember if the ATC_STR_RAT_FF even existed back with codes that can be used on that controller.
If I understand it correctly the last version I’ve got was 1.3.58 build v2.5, I know there are no more updates for APM 2.6 but for what I want to use it I don’t need more.
I just need to sort out the steering issue, and understand some of these abbreviations.
I mean what AR or Ardurover code are you using. I really can’t help without a flash log. Cant you pull out the SD card and put the flash log in the cloud somewhere so it can be seen. Google drive, dropbox, one drive.
Hello, it has been a long time since the last publication, I have the same problem, it would be very helpful for me and for the community to know how you solved this problem.
Ho @mybn001
How did you set your boat to skip some waypoints when you already sent the boat but want to send it to other waypoints?
I am not sure how to do this.
I was thinking on a “flight” plan to have 5 waypoints and after i send the boat to the first 2, i want to be able to skip them without delete them and let ghe boat go to the other remaining waypoints.
Tge logic here is if I dont delete the first 2, i can use them later if i need to send the boat there later.
Thanks!
I have instaled Pixhawk in my boat, and i have two motors and whit these motors i turn by diference of power, but the problem is that i don have the correct configuration.
Also i can’t arm from my Flysky i don’t now why but i put my left joystic down and right for more than 3 seconds and nothin happens.
