I am trying to understand the values for raw/press temp when looking at tlogs. In mission planner under status the temp is listed as four numbers. There is no decimal point. I understand it is in centigrade. At this point I am guessing where to put the decimal point based on what I believe the temp should be. As an example, yesterday when I flew it was approx 40F. The raw temp was 4298. I assume it was 4.298 C which is roughly 40F. I looked at another log from Sept and it showed a temp of 3397. It definitely was not 3.3 C in Sept where I live. But it is possible that it could have been 33.97 C. Am I looking at this correctly? Is there a way that know what the temp is without guessing where the decimal point should be.
Thanks.
