Which mode do you want to calm down? You can out Pitch_Max and Roll_Max to change the maximum lean angles, that would help. In Acro, you have Acro_RP_P that changes the angle rates.
But if you mean that the aircraft is simply too “sharp”, then you should have a look at this:
