Currently I am using telemetry 2 for Raspberry pi 4 for precision landing.
I also wanted to run mavproxy command to control the Drone over 4G LTE. For that I have to use one more raspberry pi and to be connected to telemetry 1.
You can do both with the same CC as Landing_Target is just a MavLink command like others. https://mavlink.io/en/services/landing_target.html
In order to achieve that, you must run mavproxy to connect the CC to FC over SERIAL and merge the 2 sources : GCS_over_4G LTE and Precision_Landing_Script through localhost UDP (127.0.0.1) having each sources using a different port , generally 14550 & 14560
I am controlling drone over 4G LTE on different network. Not on the same network.
I am using zero-tier for connecting mission planner on different network.
In this case is it possible? To run both the code at same time on CC?
