Hi everyone, I’m trying to establish connection between the Raspberry Pi 5 with the radiolink pixhawk V2 from the raspberry pi 5 but it seems like no serial connection is being detected by the mavproxy.
My goal is to able to run dronekit’s script in the pi and send the flight command to the pixhawk. I have been following instructions and tutorials but all of them are for Rpi4 or earlier model. I’m running the latest pi os on the pi. Did anyone manage to achieve that?
I think its not about the flight controller, because I can easily get the data from flight controller with Raspberry Pi 3 and 4. By the way, I tried both flight controllers I have; Durandal and RadioLink MiniPix. They both can connect to RPi 3 and 4 but not the RPi 5.
# For more options and information see
# http://rptl.io/configtxt
# Some settings may impact device functionality. See link above for details
# Uncomment some or all of these to enable the optional hardware interfaces
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
# Enable audio (loads snd_bcm2835)
dtparam=audio=on
# Additional overlays and parameters are documented
# /boot/firmware/overlays/README
# Automatically load overlays for detected cameras
camera_auto_detect=1
# Automatically load overlays for detected DSI displays
display_auto_detect=1
# Automatically load initramfs files, if found
auto_initramfs=1
# Enable DRM VC4 V3D driver
dtoverlay=vc4-kms-v3d
max_framebuffers=2
# Don't have the firmware create an initial video= setting in cmdline.txt.
# Use the kernel's default instead.
disable_fw_kms_setup=1
# Run in 64-bit mode
arm_64bit=1
# Disable compensation for displays with overscan
disable_overscan=1
# Run as fast as firmware / board allows
arm_boost=1
[cm4]
# Enable host mode on the 2711 built-in XHCI USB controller.
# This line should be removed if the legacy DWC2 controller is required
# (e.g. for USB device mode) or if USB support is not required.
otg_mode=1
[cm5]
dtoverlay=dwc2,dr_mode=host
[all]
dtoverlay=uart0
dtoverlay=disable-bt
dtparam=uart0
this is my config! You can chat me on discord? matheusrodriguess
and another thing, if i try mavros connect it’s work! Just uxrce no, both are running in a docker container (different containers and not the same time)
Disable agetty on /dev/ttyAMA0 agetty is typically used for serial console access. If you don’t need this, disable it. It is possible it isn’t enabled already, if not then that’s OK:
