Followed by: GPS 1: u-blox posllh rate configuration 0x3FE
All messages are these: GPS 0: detected as u-blox at 115200 baud GPS 1: u-blox posllh rate configuration 0x3FE PreArm: GPS 1 failing configuration checks PreArm: Compasses inconsistent EKF2 IMU1 is using GPS EKF2 IMU0 is using GPS EKF2 IMU1 Origin Set EKF2 IMU0 Origin Set EKF2 IMU1 tilt alignment complete EKF2 IMU0 tilt alignment complete GPS alt: 38465 Init HOME EKF2 IMU1 initial yaw alignment complete EKF2 IMU0 initial yaw alignment complete EK2: Changed EK2_GPS_TYPE to 1 GPS 0: detected as u-blox at 115200 baud Airspeed sensor calibrated Ready to fly Airspeed calibration started Barometer calibration complete PX4v2 0043002C 30365115 31313731 PX4: c4dfb9bf NuttX: 258f2257 ArduPlane V3.7.1 (22b5c415) Initialising APM Calibrating barometer
The GPS seems to work. What might be the cause of this error and what would the next step to fix it? From checking Arduplane’s code it seems to be failing to configure the NAV POSLLH messages properly. But why only these and not the others?
Following, I have this sometimes with only gps connected.
Gps 0 = primary gps
Gps 1 = secondary gps
Rebooting pixhawk solve the problem for me but why sometimes we got this error ?
It’s actually failing to configure almost everything, we simply print out the first configuration item that is failing. The 0x3FE tells me that the following messages are all failing to be configured as well : posllh rate, status rate, solution rate, velned rate, dop rate, hw monitor rate, hw2 monitor rate, raw rate, version. If you notice as well part way though the boot process the EKF gave up on trying to use the GPS as a 3D GPS. This occurs if the GPS isn’t providing us with a vertical velocity. Given that u-blox always provides this we can tell that it isn’t being correctly configured.
The most common reason for this to fail is actually bad wiring or an intermittent connection (usually on the Tx line to the GPS). Because the GPS is being detected reliably we know we are recieving at least some correct data. I’d check the wiring harness first to ensure that this all looks good.
I was thinking in the same direction because my cables indeed are not looking trustworthy. If I understand the code correctly, before the posllh-rate is configured, other must have succeeded. So it is a bit strange, that it consistently fails at exactly this point.
Is it possible, that the u-blox could be misconfigured so soundly, that I need to attach it directly to the u-center to correct some basic parameters?
Well i have the same problem with 1FFF as the rate donfiguration, and i was working fine before i made a wrong upload with QGC that erased all my AC parameters , only one m8n ublox.The position reported by the GPS is accurate.Any idea, my cable just not have become defective in few days…
