Hello folks,
I have an Ainstein US-D1 on a traditional helicopter and I would like to use it for altitude holding.
Do I have to select Rangefinder (2) in EK3_SRC1_POSZ to have it work or should it work anyway (when it measures less then RNGFND1_MAX_CM)?
TERRAIN_ENABLE must be set to enable the rangefinder?
I am testing it only in altitude hold mode.
Wiki is not clear about these things…
I did some test flights, and it does not seem to use the rangefinder to maintain height. When I am close to the ground and rangefinder height differs a lot from baro height it uses always baro height.
Am I doing something wrong?
Thanks!
