Hello
Has some one experience with the HC-SR04 I2C as a rangefinder in a Pixhawk ?
Thank you
regards
MABA64
Hello
Thank you
regards
MABA64
It was used with the APM early on and found to be ineffective. It is not recommended for use with a Pixhawk,
Are you refering to this ?
I see mixed reviews, unless they updated firmware it was not working with the latest releases of ArduPillot.
Should also add that HC-SR04 is useless in a QuadCopter because the sonar get ‘‘washed away’’ by the airflow. Benewake TFMINI lidar is an interesting alternative.
