I came across an interesting anomaly in Mission Planner 1.3.48.3 running on Windows 10 Pro when connected to an original 3DR Pixhawk with Arducopter 3.5.0-rc9 and a Lidar Lite rangefinder (1st gen.)
The Lidar Lite was originally calibrated in Mission Planner 1.3.48.3 on a Windows 7 Ultimate 64 system. When the copter is sitting on the ground and connected to MP via the Windows 7 machine, MP correctly reports the Sonar Range as 0.21m. However, when that exact same copter is connected to a different PC running Windows 10 Pro and the same release of MP (1.3.48.3), Sonar Range [erroneously] reports the distance between the Lidar Lite and the ground as 0.69m (a bit more than 3x greater.) Note the copter isn’t moving, I’m literally moving the USB cable from one PC to another. Also, peeking into the Full Parameter List indicates the value for RNGFND_SCALING is unchanged in both instances and remains set to 0.5 m/V
