I have an issue with my Hexacopter (AC 3.5.7) where it is climbing randomly during an auto grid.
The aircraft is reaching a waypoint, then shortly afterwards it is receiving a commanded climb and then descend back to normal height (aircraft slows then stops during this climb/descend). On other points during the mission, the aircraft will simply pause for a while (10 - 20 seconds) before moving on.
Your Z-axis vibrations levels are very high. In fact I don’t think I have seen an accelerometer clipping level as high as yours (>7000). Get control of that 1st.
High vibes can cause altitude instability but you are right that target altitude (Dalt) is close to actual (Balt). I think I would still address the vibe issue and then try again.
