Hello All,
I calibrated my TX last night successfully, but then realised that the program said move each channel to its extremities. I read that this process requires the trims to be centralised, but when moving a channel i.e. aileron to the right do you also have to move the right trim to its farthest setting and so on. When saving the calibration settings the trims are then moved back to central position, does this include the throttle or should it be in the lowest trim setting ?
Thanks
Andy
