I’m attempting to control servos via transmitter and receiver using Pixhawk 2.4.8 and Mission Planner. I am powering my servos separately and just have the signal and ground wires going to the pixhawk. I’ve tested out my configuration with just the receiver and it works fine. I want to be able to flip a switch and have it change to a predetermined value. I followed all the documentation, but when I try it I get a response from the controller it does nothing. What can I do to get this control?
Are you sure the Flight Controller is “Armed”? If not, nothing happens. Good Luck!
That fixed it! Thanks!
Excellent! (I’ve never done that myself you understand…. :)) Onward!
