Using Futaba 9C mode 2 with flaperon mix to drive rover in forward and reverse. That is channel 6 radio dial and channel 6 “Throttle Right” in parameters. Steering is radio channel 1 and “Throttle Left” in parameters. All that drives linear servos linked to the wheel hydros. Is the flaperon Futaba radio mix spoiling system. -Mojack
What is the simplest radio to use for this rover application. I would be happy to change radios if that simplifies things.
Your radio mix has nothing to do with auto. Instead of reversing radio channels to make manual mode work correctly, reverse servo channels to make auto mode work correctly, and then set the radio to match.
The best way would be to create a new model in the radio. No mixes, no expo, no dual rates. Ardurover expects the main controls on the input channels 1-4 by default. This can be changed, but should not be necessary. Also, RC inputs and servo outputs can be configured independently. There is no default connection between RC input 4 and servo output 4, for example.
