I am in the process of controlling my drone with navio+ and Raspberry pi as an autopilot with flysky radio transmitter receiver. I have managed to connect with APM Planner with the drone, everything is settled but when i hit calibrate button an error pops up telling me Radio control is not active or turned on . attached you can find the log file, Please any suggestion will be appreciated, Thanx.
I think you are right because i tried it with Mission planner, I could connect it but it keeps saying getting parames and it never ends. Have you any idea how to solve it. Thank you
Sorry I tried to reproduce your issue this evening but on my environment every thing works as expected. To be fair I could only test against a simulated Arducopter.
Hi, I just wanted to know if that has anything to do with the IMU (I mean sending PPM signals and get the motors running) Because something is wrong with the IMU chip. I’ll be getting another one after two weeks from now.
Thanks
hey again, i tried to calibrate the the Radio but still no luck here attached you can find the txt file, please take a look and tell me what i did wrong because i could connect the autopilot with APMplanner but this latter is not interacting or showing data. Thank you in advance apmlog_20170704.txt (429.3 KB)
Thanks a lot, Now I am facing another problem That I posted here I will be so thankful if you can help me with that.
Now I am working with mission planner. I think it is easier when doing RC calibration
PLZ take a look at it
I am facing the same problem with arducopter-3.5 on beaglebone blue.
I am using the Flysky RC radio.
Please suggest if you have found the solution.
Thanks.
