I dont understand what you mean
When the flight controller successfully connect to the Mission planner then I click on the radio calibration then click on Mandatory Hardware then again click on the Radio calibration, then I saw number of inputs get double and repeat these steps again then the inputs is increasing step by step.
Giving reply to @J4NSS3NS
I searched my old dusty radio… I took the reciever fs-ia6b (simular to yours) and flashed 4,4,2 arducopter on a cube ( i dont have pixhawk 2,4,8) … as you can see it works out of the box … radio output was set on ppm sbus /// or pwm sbus worked both.
by mistake I turned my wire on pixhawk reversed and I had of course no connection at all…
I am pretty sure about wiring now … I think we are overlooking something trivial.
first 1. check the withe/red/black futaba cable… maybe it faulty. replace it with a spare one or measure connection with multimeter
second 2. check reciever ( is it powered enough, bind properly) best case you can test one if you find someone with same model in neighbourhood.
my guess it is in your wiring somewhere…
This is meaningless and has nothing to do with your problem. Anyone can generate that.
Click off the Setup Tab and it will be normal again.
@amilcarlucas @xfacta @J4NSS3NS @dkemxr
Thank you to all form giving me a powerful support.
I have fix that following Radio calibration by matching the parameters with another Pixhawak flight controller.
I have successfully completed the all mission planner “MENDATORY HARDWARE” options but while connect the battery to drone (using 3s lipo battery) the Pixhawk shows low battery by indicating RED led but the battery having efficient charge.
I has attached the screenshot from mission planner
Please guide me what can i do for solving this problem also…
The battery must be configured before starting the mandatory hardware configuration.
See How to methodically tune (almost) any multicopter using ArduCopter 4.4.x
Dear
I have changed the Pixhawk to another one , the new Pixhawk board not showing RED led but it shows “PreArm:Fence requires position” and I am not able to ARM my quadcopter drone.
I am attaching the above problem.
Please help me by guiding me how to fix this problem.
Poor GPS position. Just because it says “3D Fix” doesn’t mean it’s good enough. Wait…
Dear
I have changed my Quadcopter Drone frame then I go for compass calibration both compass 1 and compass 2 show the green region filled in column when the compass calibration is completely filled in the column then compass 1 shows blank column region(green region) and start again from starting.
I have also attached the video link below.
Please guide me the path how to over come that problem.
Compass calibration must be done after GPS configuration and requires GPS fix during calibration and no magnetic fields in the proximity. And if that doesn’t work you need to relax the calibration.
Seams like you still haven’t read the documentation. Please do.
Hello Dear
@amilcarlucas @xfacta @dkemxr @J4NSS3NS
When I connected the battery to my Quadcopter drone the Mission planner shows “PreArm: Yaw radio max too low” and I am notable to arm my drone
I have also attached the screenshot of the problem.
PLEASE HELP
The channel that you use for yaw on your radio has a maximum value that is too low.
Re-do radio calibration step.
