Hello, I have some questions that I didn’t found on documentation or in the forum:
In the stabilize mode, the compass is used ? Is compass used on all modes ?
Some people say that you can plug the battery to the ESCs and then use the BEC to power the APM while the APM is plugged on the USB, is that correct and it is possible ? I heard someone saying that it fried the APM. If this is possible, the JP1 jumper must removed or inserted ?
My first flight was a disaster, the quadcopter (X) took off and then it started to fly towards some directions and it was very hard to control, could this be caused by interference on the compass ? Could this be caused by the unbalanced propellers ? I already checked that the motors are spinning right and also that it tries to stabilize when I hold it with my hands.
Is any GPS instrumentation used in Stabilize mode ?
In Stabilize mode, if I just level up the throttle it is supposed to stabilize it self and keep stable hovering ?
Thank you !
