I have a pixhawk 2.4.8 that came as part of a kit. The GPS module that came with it has a 5 pin connector but the Pixhawk has a 6 pin connection. Does anyone know the pinouts on the Pixhawk GPS. If I knew them I could make my own connector.
Do you mean the pinouts on the PixHawk 2.4.8 GPS port? If yes, do a google search for Pixhawk pinout.
Do you mean the pinout for the GPS module? If so, we’ll need to know what GPS module it is.
If you got it as a kit, the GPS might have come with two cables. The 5 pin connector is for the APM, and there should be a similar-looking cable with a 6 pin connector to be used with the Pixhawk. The cable can be swapped out by opening the GPS module.
I’m making assumptions because I don’t know what GPS module or kit you got, but this is true for most cases. If it’s not true for you, tell us exactly what hardware you have and we can be more specific.
