I have a PWM switch hooked up to AUXOUT 1. It is activated like a camera servo from CH8. But because of the CAM_DURATION parameter, I can only keep the PWM switch on for a maximum of 5 seconds. Is there a way to keep the PWM signal high with the camera shutter functions? Or should I use a different method to activate the signal?
