[attachment=0]2014-11-13 09-49-54.tlog[/attachment]
Looking for some help understanding what might have happened.
We were helping a class with a area protection scenario red team/blue team exercise. Blue team had air assets with live telemetry & Video.
So we were conducting a simulation for our students and were using 2 quanum Nova quads with gimble, GoPro3+, 3DR radio, 600mw TS832 for video, 3000mah 3s battery. We also had a SkyEye with pixhawk, not in the air at the time.
We had 2 ground stations running, one Nova (Kestrel) was using 3dr with a net ID of 45, and a second Nova (Peregrine) was using a net ID of 30. The SkyEye (Condor) was using a net ID of 25 but was not powered up during the incident.
We took Kestrel off, did a system check then clicked to auto and it began to move towards wp1 at 5 m/s at an altitude of 15M. Student was given control of Yaw at the ground station via joystick while I continued to watch Kestrel move down range. It started to approach the treeline, so I changed to stabilize and climbed. Due to the distance and unsure of YAW, I lost orientation. I swicthed to RTL, it didn’t move back, i went back to stabilize and it kept moving down range. There was a wind 5-10 m/s downrange. Finally, getting to small to see and starting to lose video, I put in RTL and prayed . The telemetry gives me varying amounts in the Wind_Vel parameter, but I don’t know how accurate that is and how it is calculated.
I we have is the .tlog. I am wondering if the winds aloft were too strong for RTL. Looking at the telemetry, it appears the quad was headed towards home, although the GPS track is in the opposite. Did we just get outside the envelope and unable to get back? What is the default behavior in tis situation? It was also moving over sloping terrain, so I’m not sure how it would respond to altitude. It seemed to be climbing when we finally lost signal.
First, I’d appreciate any insight into what may have happened, and, finally, if you were us, were would you be looking for this quad?
Thanks,
Kevin
