It’s been a little while since setting up a Tailsitter, but it was straight forward and I recall setting the flight modes without an issue from the pull down menus.
Now when I try all I get is the flight modes for Copter.
There are no Plane flight modes listed.
Is anyone else experiencing this.
I uninstalled MP and installed the latest, then upgraded to the latest Beta.
No change.
Does anyone have any suggestions on what might have changed or whether I am holding my tongue wrong or something.
Yes, twice.
It was my thought too.
Maybe the FW flash was bad or something.
All the QPlane parameters are there and I am having to set parameters up in the Parameters list not the setup windows.
It worked previously in earlier versions but its been quite a few months since I played with plane.
And when connected it says “plane” in the window title.
@iampete
Will try that today. I should have stated the obvious in the first post, no worries.
I often have to ask the same obvious questions when trying to help people.
It’s just such a strange occurrence.
Failing that I might try installing an older version of MP and see if things change.
