Hi
I’ve calibrate ESC motor with quadplane
When arm 4 motor spin at the same speed but I speed up there are some motor speed slow down?
Is this normal or this esc calibrate not successful
Hi
What condition are you testing this? If it’s on the bench using the transmitter it’s meaningless. Use Mission Planners Motor Test.
Thank you
I use RC transmitter speed motor up and motor automatic speed up itself
That is not a valid test so there is likely no issue or problem. Use Mission Planners Motor Test function and if the motors respond properly move on.
When use mission planner to test seem motor spin at same speed
But why sit on bench use transmitter speed motor up seem motor speed up automatic with not the same speed
That question has been answered countless times. Use forum search for “bench testing motors”.
Thank you for your answer
You mean if I put on prop it’ll work perfectly right ?
