Quadplane in sitl, trying to hold change altitude in auto mode using lua script
Hi, new to lua scripting in ardupilot,
I have been testing out a small script were i can override my sitl mission plan set altitude which is 100m to 50m.
The code looks like this:
local target_alt = 50 -- in meters
local plane_mode_auto = 10
local set_target = true
function update()
--      gcs:send_text(0, "inside update fn")
        if not arming:is_armed() then
                set_target = false
--              gcs:send_text(0, "vehicle not armed")
        else
--              gcs:send_text(0, "vehicle armed!!")
                local mode = vehicle:get_mode()
                if (mode == plane_mode_auto) then
--                      gcs:send_text(0, "in auto")
                        local curr_pos = ahrs:get_position()
                        if curr_pos then
                                curr_pos:terrain_alt(true)
                                gcs:send_text(7, string.format("alt: %d", curr_pos:alt()))
                                if curr_pos:alt() > 5000 then
                                        curr_pos:alt(curr_pos:alt() - (curr_pos:alt() - target_alt*100))
                                        gcs:send_text(6, "above limit")
                                        set_target = vehicle:set_target_location(curr_pos)
                                        gcs:send_text(0, string.format("%s",set_target))
                                elseif curr_pos:alt() < 5000 then
                                        curr_pos:alt(curr_pos:alt() + (target_alt*100 - curr_pos:alt()))
                                        gcs:send_text(6, "below limit")
                                else
                                end
                        end
                end
        end
        return update, 1000
end
return update, 1000
As i log the set_target variable im getting outputs as “False”, from the docs it means its not getting set
Am I doing something wrong here? Any help would be appreciated
