Drone takes off fine with not noticeable issue with motors. Then after severl saeconds, about 20 or 30 there is a noticeable cahnge in the engine sound accompaanied by an increase in vibrations.
I can not see anything mechanically wrong with the drone. There were a couple of loose motor screws that I had to tighten but apart from that I do not see anything out of the ordinary with the motors.
I’ve added my log and video.
So my thinking is that there might be an issue with my blheli setup?
I did get an error in Blheki 32 stating " invalid min/max throttle value, will be set to default"
There is some problem because you are not getting ESC RPM thru Bdshot. Not sure if it’s causing this instant output oscillation that you can clearly see:
For some telemetry yes but if it’s a BLheli_32 ESC using a Dshot protocol ESC RPM should be available thru Bdshot which he is using. And it’s not in the log.
Try a short flight and see if there is ESC RPM in the log. That at least will solve that problem and provide the reference for the Notch Filter when you configure it. If you didn’t figure it out already the Bdshot bitmask for chan 9-12 is 3840
