Of course, an RTF copter from 3DR would be the easiest but they’re not the cheapest, unfortunately.
If you can live with crappy service, I’d suggest the following setup made from Hobby King stuff:
Cheap but sturdy frame (you will crash many times):
Hobby King H4 Frame $29,99
hobbyking.com/hobbyking/stor … duct=35908
Here’s a good and cheap speed controller for quadcopters which will save you tons of wiring work. Additionally, Our developers found that those all-in -one ESCs produces less EM interference which would mess with the compass than using a PDB and 4 separate ESCs. NOTICE: It does NOT have a battery connector. You need to solder the right one for the battery you buy.:
Q Brain 4 x 25A Brushless Quadcopter ESC 2-4S 3A SBEC
$33,18
hobbyking.com/hobbyking/stor … =q%20brain
These motors are pretty ok. I built my first quads with them.
4x NTM Prop Drive 28-30S 800KV / 300W Brushless Motor (short shaft version)
4x $15,29
hobbyking.com/hobbyking/stor … sion_.html
Then you need prop adapters:
4x NTM Prop Drive 28 Series Accessory Pack
4x $1,89
hobbyking.com/hobbyking/stor … ntm%20acce
Then some props. Although you will crash and break them, you should buy better props right away because bad props cause vibrations and flex and then the whole copter won’t fly nice!
2 Packs of those are minimum (=4 props). Buy more - you’ll need them!
2x 10x4.5 Carbon Fiber Propellers 1pc Standard/1pc RH Rotation
2x $6,61
hobbyking.com/hobbyking/stor … ation.html
The battery should be good quality too. The setup I wrote down for you here is for 4S. I’d recommend something like this:
Turnigy nano-tech 4000mah 4S 25~50C Lipo Pack
$38,59
hobbyking.com/hobbyking/stor … _Pack.html
So, all in all, you’d spend $198,99 and you’d have a very nice beginner-friendly quadcopter. Of course, then you still need the APM/Pixhawk and GPS/Compass and maybe telemetry radios.
Once you got the basic flying skills, you can start looking e.g. into mounting a camera and a video transmitter to you quad and go autonomous. With those props and motors if you stay under 1,2-1,5kg you should get about 15-20 minutes flight time out of a 4Ah battery. At least I got
