I recently build a f450 Quadcopter. I am using APM 2.8 and it is flashed with version 3.2.1. I am using flysky fs-i6 transmitter and iA6b receiver. It is mode 2 transmitter. The problem I am facing is that when I push the right stick of the transmitter backwards the drone move forwards and when I push the right stick of my transmitter forwards the drone move backwards. I can’t fly my drone because of this. I have properly callibrated my esc , accelerometer , transmitter , compass. Plz help me as soon as possible. I am really in need of help. Plz reply fast. Thanks in advance.
Try to check the parameters of the elev in your transmitter in the page mixer, if ele param is 100 you must set it - 100. After you have done this just test it.
For the test just tighten the drone with a cable
Does reversing the pitch channel will work ???
yes, and test it.
Just tighten the drone first and try
Thanks a lot it worked God bless you
