Hi all,
I built a quad with a dji flamewheel f450 frame and the pixhawk and it all flies normally when in stabilize and alt hold modes. However when I tested RTL mode it went up to altitude and flew in a curve past home not passing over it at about 30mph and then crashed into the ground. An auto analysis of the log came up with this:
[code]Log File C:/Program Files (x86)/Mission Planner/logs/QUADROTOR/1/2014-12-13 20-00-38 5.bin.log
Size (kb) 2542.4033203125
No of lines 35195
Duration 0:07:05
Vehicletype ArduCopter
Firmware Version V3.1.5
Firmware Hash ee63c88b
Hardware Type
Free Mem 0
Skipped Lines 0
Test: Balance/Twist = GOOD -
Test: Brownout = FAIL - Truncated Log? Ends while armed at altitude 3.68m
Test: Compass = FAIL - Large compass off params (X:-24.74, Y:-32.41, Z:-159.02)
Large compass offset in MAG data:
Z: -159.00
mag_field interference within limits (9.91%)
Max mag field length (560.95) > recommended (550.00)
Test: Dupe Log Data = GOOD -
Test: Empty = GOOD -
Test: Event/Failsafe = GOOD -
Test: GPS = GOOD -
Test: Parameters = GOOD -
Test: PM = GOOD -
Test: Pitch/Roll = GOOD -
Test: Thrust = FAIL - Avg climb rate 7.00 cm/s for throttle avg 718
Test: VCC = GOOD -
[/code]
Somewhere in the chain of events my gps mast broke and my battery and 3dr power module seperated from the quad… I was told before it could be my HDOP… Also when I fly in loiter mode the quad drifts rapidly away at app. 20 mph+. The log files from the incident are attached.
All help is appreciated,
L
