Hey,
I was wondering if anyone has experimented running quad copter firmware on an octocopter style frame? What I mean is instead of a traditional octo where every second motor spins CCW and every other CW, I want to have motors A and B spinning in the same direction, C and D spinning the opposite, E and F the same as A and B, G and H as C and D?
Basically I want a coaxial quad setup with the efficiency of an octocopter and only require 4 motor output signals.I will split the output signal for motor 1 to the ESCs of motors A and B, the motor signalfor motor 2 to the motors E and F and so on…
Is there any reason this won’t work?
Regards,
Cameron
