QGroundControl with Video down link on Linux?
I have just installed the QGroundControl 2.0 software on Windows and it looks real cool, but I like to use it on my Linux U2 micro system. Dose anyone knows where I can find Linux version from this software and how I can get the video downlink implemented?
Best regards from Austria
Frank
You need to compile it on Linux from source, see here.
http://qgroundcontrol.org/dev/build_source
HTH.
Pete.
[quote=“pete910”]You need to compile it on Linux from source, see here.
HTH.
Pete.[/quote]
:astonished: I thought it will be a little bit more a install and run solution. But I will try to get it work, thank´s a lot.
What distro are you running , eg : Mageia, Fedora, Ubuntu, Arch ?
Also 32 or 64 bit os?
Personally running Mageia 3 64bit.
Pete.
He (and me too) is using a APMv7-powered board with Ubuntu 13.04.
There is already an option to enable something like “video downlink” but it has no affect (I am using windows 8). How do I use this feature? Is it possible to use a standard webcam inuput?
[quote=“pete910”]What distro are you running , eg : Mageia, Fedora, Ubuntu, Arch ?
Pete.[/quote]
Hello Pete
peter was faster than me :slight_smile:
Frank
Not used the video link myself, still learning the whole uav thing tbh. :wink:
But I can help getting qgroundcontrl working/compiled with you.
If you follow the instructions from the link I posted you shouldn’t go far wrong.
Pete
