This is my first Pixhawk build. If there is a simple solution to this, I’m sorry, I swear I’ve done a lot of searching.
Stack:
Holybro Pixhawk runing Arduplane 3.9.1
Holybro 915mhz SiK radios with factory firmware
Mac OS 10.13.6
QGroundControl 3.4.2
System Information says the radios are manufactured by FTDI.
I have installed the Serial USB drivers from FTDI on the Mac.
When I plug the radio into the Mac, it appears to be communicating - when I turn heartbeat on and off in QGC, the radio’s leds reflect the change.
The radio connected to the Mac is flashing green, flashing red, and doing a double orange flash.
The radio attached to the Pixhawk is flashing red, no green led, no orange led.
I can connect to the Pixhawk via USB, but I can’t connect via SiK.
I’m guessing that the problem is with the Pixhawk’s radio, because it doesn’t appear to be searching for another radio? I’ll keep scouring the web for solutions, but any advice would be greatly appreciated!
-Mike
