Hi ,
I am unable to use Benewake TF02Pro Range Finder , configuring Serial 4 (GPS2). at 115200 Baud Rate, Adding RNGFIND1 Settings, Show Range Finder Error.
Any Leads will be appreciated.
Thnks
Hi ,
Thnks
Check configuration and wiring:
Here is my configuration (I use Serial 2 with TF02-Pro, Serial 4 is used by my second GPS)
TF02Pro can work at 5Volts but it need enough power (unavailable from PixHawk). It is better to feed it with 12 volts from external source.
Check also Serial wiring (Tx to Rx), it could be inverted.
Hi , I am unable to get the TF02 Pro Working , I am attaching my configuration.
It is connected to GPS 2 Port Pin2 MCU_TX and PIN3 MCU_RX on PIXHAWK ORANGE CUBE.
Are You using the SCL and SDA pins on the Serial connection instead of MCU_TX and MCU_RX
What is this RngFNDA ? Should I try using that ?
I am supplying 7V to the Tf02 Pro Benewake Sensor.
@mlebret Thanks so much, I reflashed with ArduCopter 4.0.3 and Voila, it works now !!
There may be a glitch in 4.0.7 for Benewake Tf-02 Pro when connecting via serial ports.
