The decimal for battery current seem to be at the wrong place But it clearly says A.
The decimal should be 2 digits to the left then it would be correct.
In the picture below the vehicle is using 12.84A (not 1284A )
On a side not, you are doing and awesome job with QGC, I like it more and more everyday.
PS: there is another data under the “battery” section, called “time remaining” or something like that. When that is selected it does not show any data. Just “00” or “…”. Even thought I was flying a mission and the speed was configured. That should be a calculated data if I understand correctly.
This comes from BATTERY_STATUS.time_remaining telemetry. It’s up to the firmware to send it. You should be able to use mavlink inspector to see the raw value being sent from the vehicle. If the value in the inspector looks valid but QGC is showing crap let me know. If the value = 0 then the firmware isn’t sending the value and you should report firmware bug.
Hey Don, sorry, I was checking Play store today and the (daily) version there shows last update 8th nonmember. How can I get the version with this PR in it?
