Hello everyone.
I have replaced SIK radio with ELRS Airport and it works just fine with Mission Planner but failed to connect with QGC. Does any of you have experience with the combination QGC and ELS Airport?
//YB
Hello everyone.
//YB
Have you tried manually configuring QGC connection?
I have tried setting Com links, serial, baudrate 4800 with no success in connecting. I then tried connecting Mission Planner for Android to the same tablet and it works perfectly. I can try again, but which setting should I change?
Regards //YB
Try using the same settings that worked with Mission Planner.
