Hello everyone.
I wanted to understand the parameter Q_WP_SPEED_UP (or Q_WP_SPEED_DN). The documentation defines this as “Waypoint Climb Speed Target: Defines the speed in cm/s which the aircraft will attempt to maintain while climbing during a WP mission.”
Naturally, I thought that the vertical velocity of the aircraft would be defined by this. That is, if the next waypoint is at an altitude greater than the current flight level, and also is very far away, I thought the aircraft would fly with Q_WP_SPEED_UP until the next WP height (not the WP itself) is achieved and then fly level to the waypoint. However, this was not the case. The aircraft did a “straight-line flight” to the waypoint (i.e. nose pointing towards the WP at all times, a slow and constant climb).
This made me think that maybe Q_WP_SPEED_UP defines the maximum vertical speed during WP missions. So I made a mission where two WP were 50 meters apart in the x-y plane, and the height difference was 150 meters. After reaching first WP, the aircraft started to climb at velocities almost 2 times the Q_WP_SPEED_UP. So, my assumption was wrong again.
Q_WP_SPEED_UP is neither the minimum, nor the maximum, and not something the aircraft maintains at all times in a WP mission.
So if someone could explain this parameter to me, that would be great.
I did these mission tests in Mission Planner SITL. The flight was in FW mode. One more thing could be that this parameter only defines the Quad part of the QuadPlane. I don’t know.
Anyway, thanks in advance!
