I should had find this out by myself. The ‘*’ is just logical.
But i get the next Error:
Traceback (most recent call last):
File "C:\Users\USERNAME\AppData\Local\Programs\Python\Python310\Lib\site-packages\pymavlink\mavlogdump.py", line 237, in <module>
match_types.append("FMT")
AttributeError: 'NoneType' object has no attribute 'append'
I watched into the Code and thought about editing it, but i dont think thats the right way… I think i installed pymavlink not the correct way or have some configuration problems.
Then i downloaded the mavlogdump.py from Github and dragged it into my pymavlink-Installation-Folder, because i wasnt able to locate it inside this folder.
For starting the script i run cmd from inside the pymavlink-Installationfolder.
I tried this solution but it resulted in the same error again. I ran all the 3 commands mentioned above in this post and it still ran into the same error.What I did different was install pymavlink without necessarily installing the other python packages first
