IgorSoares
(Igor Mayer Soares)
#1
I’m trying to connect Lightware’s Lidar LW20 using my Px4 with Arduplane 4.1.1, but it doesn’t work.
When I load ArduCopter 4.0.7, it works perfectly.
Same parameters in both:
SERIAL2_BAUD = 115
SERIAL2_PROTOCOL = 9
Has anyone had the same problem?
Why don’t you try ArduPlane 4.1.7?
Jigyasu
(Jigyasu Chand)
#3
Did you set the RNGFNDx_TYPE and the other parameters?
If not, check out the ArduPlane documentation for LightWare LW20
IgorSoares
(Igor Mayer Soares)
#4
Yes, I did. I’ll update to 4.1.7 and try again.
Thank you
