Hello.
I have a HobbyKings S500 QUADCOPTER and just brought a PX4 Optical Flow Kit and i encounter some problems with it. This is the product :
https://pixhawk.org/modules/px4flow
I am using ArduCopter 3.3 (don’t know what RC, maybe the lastest)
I encounter a dozens of problems :
When i am running the DRONE from the battery i see no optical flow in dataflash logs at all.
When i am running the DRONE from the battery sometimes i see BAD GYRO HEALTH error and can’t ARM because of this, sometimes not.
When i am running from USB, i can see OF logs in dataflash logs, but the EKF5.meaRng is just a flat line, even though i change the height of the drone, i see nothing. If the sonar was working i should see a more precise ALTITUDE, right?
When i am running from USB, i see “Bad LiDAR Health” and in QgroundController i see “pre arm check range finder” errors
DATAFASH LOG 1 (when i have the usb connected)
http://www.filedropper.com/2016-03-3007-10-304onusb
DATAFLASH LOG 2 (when i give current from the battery)
http://www.filedropper.com/2016-03-3007-10-053onbattery
I also had to change FLOW_ORIENT_YAW from 0 to -9000 in order to calibrate the sensor.
I have updated the firmware of PX4FLOW using the px4flow-klt-06Dec2014.px4 file (found here http://ardupilot.com/downloads/?did=118) where some says that is the best.
How it looks like now when running from USB :
[IMG1] IMU.GyrX with FlowX and BodyX
[IMG2] IMU.GyrY with FlowY and BodyY
Other images :
The dataflash logs are just tests, i was not flying drone, just moving it around from hand.
TUTORIALS :
http://ardupilot.org/copter/docs/common-px4flow-overview.html
Optical Flow discussion thread - Discussions - diydrones (Goro Senzai post)
Any ideea? Please.
Thanks.
