The Pixhawk documentation states that the RSSI signal can be either PWM or analog (one of the reasons I upgraded from my APM2.6)
I am running 3.1.2 firmware.
I have connected the PWM RSSI output from my EZUHF receiver to Pin 103 (SBUS) but can’t figure out how to configure the Pixhawk to take the PWM signal. How do I configure this?
[quote=“turdsurfer”]Hi Craig,
Can I assume from that, that analog RSSI code has been implemented already and that I can use the SB port for it?
Thanks,
Craig[/quote]
I’ve got analog RSSI working on pin 13 (0-3.3v) with FRSKY x8r.
I haven’t tried the SB pin (Should be 103). Try it in the parameters and see if it works.
