Hi everyone
I am currently working on a project that requires me to get 0-5V style pwm out of the pixhawks main or aux outputs does anyone know if this can be done or able to suggest any alternatives
Thanks
Hi everyone
Thanks
The Pixhawk outputs 3.3V PWM. You will need an external level converter
how do you get the pwm to give you a voltage between 0- 3.3V as opposed the the servo style pulse
Basically i need to be able to edit to duty cycle to run a non servo motor through a motor controller
