I have a number of copters, but a shortage of cubes. I noticed that there is now a purple version that is significantly less expensive than the black one.
Why are the reasons that I would choose a Black Cube over a Purple Cube?
In addition, I also have a 3DR Solo in the corner with a stock cube. I know I can solder the jumper to make a black cube to 5v instead of using a green cube. Does the purple cube also have that ability?
Black and Blue Cubes also feature triple redundant IMUs. Purple only has 1 IMU. Again, this would become important when flying as opposed to a ground vehicle. Obviously, there is a lower risk of injury/damage when a ground vehicle suffers an IMU failure.
