Hello why st24 protocol rc (1024) not work in ardurover v4.4.0 stable ?
But work in ardurover v4.5.0 master
I use the st16 with qgroundcontrol with an esp transform the yuneec protocol into ppm
it would be cool to use directly on the dms port
he walks with the master
but not with the stable
So use Master.
yes but I ask myself the question is the dev firmware dangerous to use or not
like the beta
AFAIK Master isn’t recommend for operational use. IMHO if you have the necessary capabilities you should consider back porting it onto stable.
Create a GitHub issue requesting the backport. If the bug is as serious as the PR indicates, that should’ve been done already anyway.
hello yes I think that this had been done but the st24 protocol only works in master
It does not appear to have been backported, which is why you should create the GitHub issue to request it.
I hope the request will be validated
Thank you Yuri_Rage
I made the request but it was the first time I requested a backreport without really knowing how
