Beginner at programming
Cant figure out which one of the given examples is using Profi LED
Is there some documentation on how to use Profi LED with lua script
Till now I have managed to set Profi LED as notification LED’s
Thanks,
MindProbe
Thanks,
MindProbe
All the examples can use both,
You just need to comment in the correct setup function.
Just load the script and change your notify output to Scripting1
Thanks a lot @iampete
for others who come looking for this in the future
serialLED:set_num_profiled(10, 8)
function update_LEDs()
serialLED:set_RGB(10, 0, 255, 0, 0)
serialLED:set_RGB(10, 1, 255, 0, 0)
serialLED:set_RGB(10, 2, 255, 0, 0)
serialLED:set_RGB(10, 3, 255, 0, 0)
serialLED:set_RGB(10, 4, 0, 255, 0)
serialLED:set_RGB(10, 5, 0, 255, 0)
serialLED:set_RGB(10, 6, 0, 255, 0)
serialLED:set_RGB(10, 7, 0, 255, 0)
serialLED:send(10)
return update_LEDs, 2000
end
This is for the new Hexsoon EDU 450 quadcopter with 4 Leds connected to Hexsoon 40A PDB
Each LED has 2 individual profiLeds inside and can be controlled seperately
The signal port on the pdb has two outputs :
Brown is Data
Black is Clock
And the white wire in both connector is ground
Connect connector with black wire in AUX1 and brown in AUX2
Set these parameters
SERVO9_FUNCTION 132
SERVO10_FUNCTION 94
SCR_ENABLE 1
and upload the above script
This makes the front two Red and the rear two green (depends on which led is connected to which port on the PDB)
A few notes to improve your script:
Here’s a revised version that’s admittedly a little longer and includes a minor amount of complexity for example’s sake, but it’s hopefully easier to read and modify:
-- configuration "constants"
local SERVO_FN = 94
local NUM_LEDS = 8
local MAV_SEVERITY_INFO = 6
-- color "constants"
local R = 0
local G = 1
local B = 2
local RED = {
[R] = 255,
[G] = 0,
[B] = 0
local GREEN = {
[R] = 0,
[G] = 255,
[B] = 0
-- helper function to set sequential LEDs to a certain color
local function set_led_colors(channel, index_first, index_last, color)
for i = index_first, index_last do
serialLED:set_RGB(channel, i, color[R], color[G], color[B])
end
end
-- find servo channel for LEDs
local CHAN = SRV_Channels:find_channel(SERVO_FN)
-- exit gracefully if parameter not set
if not CHAN then
gcs:send_text(MAV_SEVERITY_INFO, string.format('LEDs: Channel (%d) not set', SERVO_FN))
return
end
-- according to comment from LED_roll.lua example - possibly unnecessary with more recent versions?
-- slightly breaks my usual convention of all caps for "immutable" pseudo-constants, but this is the last time we will change its value, so I prefer this capitalization style here
CHAN = CHAN + 1
-- configure LED driver
serialLED:set_num_profiled(CHAN, NUM_LEDS)
-- set first half to RED
set_led_colors(CHAN, 0, math.floor(NUM_LEDS / 2), RED)
-- set second half to GREEN
set_led_colors(CHAN, math.ceil(NUM_LEDS / 2), NUM_LEDS - 1, GREEN)
-- commit color changes
serialLED:send(CHAN)
gcs:send_text(MAV_SEVERITY_INFO, string.format('LEDs (%d): Colors set', NUM_LEDS))
-- no need to call an update function - this runs once
Fair warning - I did not test the revision, so I apologize for any typos or errors.
Barring silly mistakes on my part, if it doesn’t work, perhaps the Lua scripting engine is loaded before the LED driver is ready. In that case, it’s pretty easy to encapsulate the bulk of the script inside a function that could be called after a couple of seconds.
Thanks a lot @Yuri_Rage ,
local SERVO_FN = 94
local NUM_LEDS = 8
local R = 0
local G = 1
local B = 2
local RED = {
[R] = 255,
[G] = 0,
[B] = 0
local GREEN = {
[R] = 0,
[G] = 255,
[B] = 0
end
end
if not CHAN then
return
end
CHAN = CHAN + 1
function updateloop()
return updateloop, 2000
end
Your revision worked after adding those three lines inside an update loop. But it should’ve worked without it.
I didn’t get what you meant by this, could you explain a little bit more
It looks like this may be the reason you needed to use a recursion loop to get things to work. If the script runs before the LED driver is loaded/ready, any calls to it will be ineffective.
Instead of using a loop, let’s try this simple change. If it still doesn’t work (for reasons I can’t explain), your looped version isn’t necessarily bad, as there will be very little processing time used.
local SERVO_FN = 94
local NUM_LEDS = 8
local BOOT_DELAY_MS = 2000
local R = 0
local G = 1
local B = 2
local RED = {
[R] = 255,
[G] = 0,
[B] = 0
local GREEN = {
[R] = 0,
[G] = 255,
[B] = 0
end
end
if not CHAN then
return
end
CHAN = CHAN + 1
function run_once()
end
return run_once, BOOT_DELAY_MS
Works like a charm when BOOT_DELAY_MS set to 3000
Thanks for all of it @Yuri_Rage
Also I made a simple program that blinks led when disarmed and makes them solid when armed. Thanks a lot, @iampete for helping me on discord
Although its not as readable and user friendly as yuri’s but could help someone looking for something similar
local chan = SRV_Channels:find_channel(94)
local num_leds = 8
chan = chan + 1
function led_always_ON()
for led = 0, num_leds-5 do
serialLED:set_RGB(chan, led, 255, 0, 0)
end
for led = 4, num_leds-1 do
serialLED:set_RGB(chan, led, 0, 255, 0)
end
serialLED:send(chan)
if not arming:is_armed() then
gcs:send_text(6, "Disarmed")
return led_OFF,10
end
return led_always_ON,100
end
function led_ON()
end
end
if arming:is_armed() then
gcs:send_text(6, "Armed")
end
return led_OFF,500
end
function led_OFF()
serialLED:set_RGB(chan, led, 0, 0, 0)
end
end
end
return led_ON,500
end
serialLED:set_num_profiled(chan, num_leds)
return led_always_ON,1500
