Problems with win7 64bit
Well, I instaled a win7 64 bit clean on my Compaq Q10- 500:
Intel Atom CPUN455 1.66 is dual
2 Gb Ram
Intel graphics Media Accelerator 3150
All with the last drivers Direct X and Updates
First at all, I’m installed Mission Planner …didn’t work because the Direct X was 11 and this program need the Direct 9c, Installed this one all is running and work.
Latter I installed the apmplanner2-installer-win32 (2.0.25) and the program start to running but never finish the start… , Check the .NET and I have Framework 4.7.1 and I tried to install the earlier from 3.5 until 4.6.1, but It’s impossible I don’t know what I can do in order to run the APM 2. Please Help.
Do this please: Right mouse click on the APMPlanner2 icon and choose “Run as administrator” and then capture the output from the command prompt window and post here so I can look at it.
Hi Carpy , I tried it several time but was impossible. and then I made a video. You can see it here https://youtu.be/cqdovmIqLZg thank you.
Normally APM planner creates a logfile, but I don’t know where it is located on windows. Without having a logfile it will be very difficult to find out what goes wrong.
But I am sure @carpy knows it - or he has an Idea how to capture the output.
Just one year of Spanish is not going to cut it. :slight_smile:
You should see a log (apmlog_date.txt) in your home directory. For me the logs are found here:
C:\Users\Dave\apmplanner2
ok Carpy… Sorry jejejejje.
here you have it.
[20180215 17:47:33.555 INFO ] - QGCCore::initialize()
[20180215 17:47:33.618 INFO ] - Current Build Info
[20180215 17:47:33.618 INFO ] - Git Hash: d9bae3ff52e8b1a656694282d76faec35c140094
[20180215 17:47:33.618 INFO ] - Git Commit: 2.0.25-rc1-31-gd9bae3ff5-DEV
[20180215 17:47:33.618 INFO ] - APPLICATION_NAME: “APM Planner”
[20180215 17:47:33.618 INFO ] - APPLICATION_VERSION: “v2.0.25”
[20180215 17:47:33.618 INFO ] - APP_PLATFORM: win
[20180215 17:47:33.618 INFO ] - APP_TYPE: stable
[20180215 17:47:54.558 INFO ] - Start Link Manager
[20180215 17:47:54.559 DEBUG] - Create MAVLinkDecoder: MAVLinkDecoder(0x29c0080)
[20180215 17:47:54.745 INFO ] - Start UAS Manager
[20180215 17:48:09.577 DEBUG] - Creating MainWindow
[20180215 17:48:17.348 INFO ] - Creating SubMainWindow: SubMainWindow(0x2343ca0)
[20180215 17:48:17.349 INFO ] - setting objectName: “VIEW_MISSION”
[20180215 17:48:17.870 INFO ] - Creating SubMainWindow: SubMainWindow(0x2af7ff0)
[20180215 17:48:17.871 INFO ] - setting objectName: “VIEW_FLIGHT”
[20180215 17:48:18.132 INFO ] - Creating SubMainWindow: SubMainWindow(0x2af8cf0)
[20180215 17:48:18.133 INFO ] - setting objectName: “VIEW_HARDWARE_CONFIG”
[20180215 17:48:20.524 DEBUG] - fillPortsInfo
[20180215 17:48:21.730 WARN ] - libpng warning: iCCP: known incorrect sRGB profile
[20180215 17:48:21.812 WARN ] - libpng warning: iCCP: known incorrect sRGB profile
[20180215 17:48:21.829 WARN ] - libpng warning: iCCP: known incorrect sRGB profile
[20180215 17:48:25.962 INFO ] - Creating SubMainWindow: SubMainWindow(0x4315640)
[20180215 17:48:25.963 INFO ] - setting objectName: “VIEW_SOFTWARE_CONFIG”
[20180215 17:48:26.232 DEBUG] - Disable Controls
[20180215 17:48:28.614 INFO ] - Creating SubMainWindow: SubMainWindow(0x46bd720)
[20180215 17:48:28.615 INFO ] - setting objectName: “VIEW_ENGINEER”
[20180215 17:48:28.747 INFO ] - Creating SubMainWindow: SubMainWindow(0x46c4ba0)
[20180215 17:48:28.748 INFO ] - setting objectName: “VIEW_SIMULATOR”
[20180215 17:48:29.237 DEBUG] - MODE: 0
[20180215 17:48:29.375 DEBUG] - “D|PREFLIGHT”
[20180215 17:48:29.384 DEBUG] - MODE: 80
[20180215 17:48:29.388 DEBUG] - “D|STABILIZED”
[20180215 17:48:29.392 DEBUG] - MODE: 64
[20180215 17:48:29.395 DEBUG] - “D|MANUAL”
[20180215 17:48:29.399 DEBUG] - MODE: 88
[20180215 17:48:29.402 DEBUG] - “D|VECTOR|STABILIZED”
[20180215 17:48:29.440 DEBUG] - MODE: 92
[20180215 17:48:29.444 DEBUG] - “D|AUTO|STABILIZED”
[20180215 17:48:29.450 DEBUG] - MODE: 66
[20180215 17:48:29.454 DEBUG] - “D|TEST”
[20180215 17:48:30.574 DEBUG] - QUrl(“file:///C:/Program Files (x86)/APMPlanner2/qml/PrimaryFlightDisplayQML.qml”)
[20180215 17:48:40.616 DEBUG] - QML Status: 1
[20180215 17:48:40.729 DEBUG] - QUrl(“file:///C:/Program Files (x86)/APMPlanner2/qml/PrimaryFlightDisplayQML.qml”)
[20180215 17:48:41.322 DEBUG] - QML Status: 1
[20180215 17:48:41.367 INFO ] - UASActionsWidget creating UASActionsWidget(0x4d1c710)
[20180215 17:48:41.392 DEBUG] - QuickView: load settings
[20180215 17:48:41.416 DEBUG] - QuickView: loading key: “GCS GPS.GPS Fix ()” type: “text”
[20180215 17:48:41.507 DEBUG] - QuickView: loading key: “GCS GPS.GPS HDOP ()” type: “text”
[20180215 17:48:41.529 DEBUG] - QuickView: loading key: “GCS GPS.GPS Sats (n)” type: “text”
[20180215 17:48:41.545 DEBUG] - QuickView: loading key: “GCS Metric.Alt MSL (m)” type: “text”
[20180215 17:48:41.573 DEBUG] - QuickView: loading key: “GCS Metric.Alt REL (m)” type: “text”
[20180215 17:48:41.616 DEBUG] - QuickView: loading key: “GCS Status.Battery (%)” type: “text”
[20180215 17:48:41.651 DEBUG] - QuickView: loading key: “GCS Status.Climb (m/s)” type: “text”
[20180215 17:48:41.680 DEBUG] - QuickView: loading key: “GCS Status.Current (A)” type: “text”
[20180215 17:48:41.724 DEBUG] - QuickView: loading key: “GCS Status.Pitch (deg)” type: “text”
[20180215 17:48:41.791 DEBUG] - QuickView: loading key: “GCS Status.Roll (deg)” type: “text”
[20180215 17:48:41.964 DEBUG] - QuickView: loading key: “GCS Status.Voltage (V)” type: “text”
[20180215 17:48:42.019 DEBUG] - QuickView: loading key: “GCS Status.Yaw (deg)” type: “text”
[20180215 17:48:42.154 DEBUG] - QuickView: load settings END
[20180215 17:48:43.073 DEBUG] - qmlBaseDir “C:/Program Files (x86)/APMPlanner2”
[20180215 17:48:43.106 DEBUG] - QUrl(“file:///C:/Program Files (x86)/APMPlanner2/qml/ApmToolBar.qml”)
[20180215 17:48:43.651 DEBUG] - APMToolBar: button label SELECTED
[20180215 17:48:44.512 DEBUG] - QML Status: 1
[20180215 17:48:44.531 INFO ] - NETWORK_PROXY: Disabling System Network Proxies
[20180215 17:48:44.581 INFO ] - Screen Size is QRect(0,0 1024x600)
[20180215 17:48:45.953 WARN ] - QSettings::endGroup: No matching beginGroup()
[20180215 17:48:45.966 DEBUG] - Create Serial Connection: SerialConnection(0x22e0c20)
[20180215 17:48:45.981 INFO ] - No Ports Found ()
[20180215 17:48:45.997 INFO ] - “No Devices” 115200
[20180215 17:48:46.013 DEBUG] - APMToolBar: new Serial Link Created 1
[20180215 17:48:46.028 DEBUG] - APMToolBar setConnection: false
[20180215 17:48:46.028 DEBUG] - APMToolBar: updateLinkDisplay “No Devices” : “115200” connected: false
[20180215 17:48:46.044 INFO ] - UDP Created “UDP Link (port:14550)”
[20180215 17:48:46.059 INFO ] - UDPLink::UDP connect QHostAddress(QHostAddress::Any) : 14550
[20180215 17:48:46.559 DEBUG] - SCW: Link is disconnected
[20180215 17:48:46.574 INFO ] - No Ports Found ()
[20180215 17:48:46.590 DEBUG] - Baud rate: 115200 Expected: 4
[20180215 21:58:26.755 INFO ] - QGCCore::initialize()
[20180215 21:58:26.755 INFO ] - Current Build Info
[20180215 21:58:26.755 INFO ] - Git Hash: d9bae3ff52e8b1a656694282d76faec35c140094
[20180215 21:58:26.755 INFO ] - Git Commit: 2.0.25-rc1-31-gd9bae3ff5-DEV
[20180215 21:58:26.755 INFO ] - APPLICATION_NAME: “APM Planner”
[20180215 21:58:26.755 INFO ] - APPLICATION_VERSION: “v2.0.25”
[20180215 21:58:26.755 INFO ] - APP_PLATFORM: win
[20180215 21:58:26.755 INFO ] - APP_TYPE: stable
[20180215 21:58:34.087 INFO ] - Start Link Manager
[20180215 21:58:34.087 DEBUG] - Create MAVLinkDecoder: MAVLinkDecoder(0x2a30080)
[20180215 21:58:34.134 INFO ] - Start UAS Manager
[20180215 21:58:38.357 DEBUG] - Creating MainWindow
[20180215 21:58:39.725 INFO ] - Creating SubMainWindow: SubMainWindow(0x2205cb0)
[20180215 21:58:39.726 INFO ] - setting objectName: “VIEW_MISSION”
[20180215 21:58:40.014 INFO ] - Creating SubMainWindow: SubMainWindow(0x2ba1f70)
[20180215 21:58:40.015 INFO ] - setting objectName: “VIEW_FLIGHT”
[20180215 21:58:40.193 INFO ] - Creating SubMainWindow: SubMainWindow(0x2ba2c70)
[20180215 21:58:40.195 INFO ] - setting objectName: “VIEW_HARDWARE_CONFIG”
[20180215 21:58:40.982 DEBUG] - fillPortsInfo
[20180215 21:58:41.540 WARN ] - libpng warning: iCCP: known incorrect sRGB profile
[20180215 21:58:41.558 WARN ] - libpng warning: iCCP: known incorrect sRGB profile
[20180215 21:58:41.575 WARN ] - libpng warning: iCCP: known incorrect sRGB profile
[20180215 21:58:42.855 INFO ] - Creating SubMainWindow: SubMainWindow(0x4624160)
[20180215 21:58:42.857 INFO ] - setting objectName: “VIEW_SOFTWARE_CONFIG”
[20180215 21:58:42.961 DEBUG] - Disable Controls
[20180215 21:58:44.423 INFO ] - Creating SubMainWindow: SubMainWindow(0x4995cf0)
[20180215 21:58:44.424 INFO ] - setting objectName: “VIEW_ENGINEER”
[20180215 21:58:44.494 INFO ] - Creating SubMainWindow: SubMainWindow(0x499d0f0)
[20180215 21:58:44.495 INFO ] - setting objectName: “VIEW_SIMULATOR”
[20180215 21:58:44.729 DEBUG] - MODE: 0
[20180215 21:58:44.788 DEBUG] - “D|PREFLIGHT”
[20180215 21:58:44.791 DEBUG] - MODE: 80
[20180215 21:58:44.797 DEBUG] - “D|STABILIZED”
[20180215 21:58:44.806 DEBUG] - MODE: 64
[20180215 21:58:44.811 DEBUG] - “D|MANUAL”
[20180215 21:58:44.818 DEBUG] - MODE: 88
[20180215 21:58:44.824 DEBUG] - “D|VECTOR|STABILIZED”
[20180215 21:58:44.831 DEBUG] - MODE: 92
[20180215 21:58:44.837 DEBUG] - “D|AUTO|STABILIZED”
[20180215 21:58:44.844 DEBUG] - MODE: 66
[20180215 21:58:44.850 DEBUG] - “D|TEST”
[20180215 21:58:45.771 DEBUG] - QUrl(“file:///C:/Program Files (x86)/APMPlanner2/qml/PrimaryFlightDisplayQML.qml”)
[20180215 21:58:51.000 DEBUG] - QML Status: 1
[20180215 21:58:55.360 DEBUG] - QUrl(“file:///C:/Program Files (x86)/APMPlanner2/qml/PrimaryFlightDisplayQML.qml”)
[20180215 21:58:55.804 DEBUG] - QML Status: 1
[20180215 21:58:55.894 INFO ] - UASActionsWidget creating UASActionsWidget(0x4aacc30)
[20180215 21:58:55.921 DEBUG] - QuickView: load settings
[20180215 21:58:55.930 DEBUG] - QuickView: loading key: “GCS GPS.GPS Fix ()” type: “text”
[20180215 21:58:56.044 DEBUG] - QuickView: loading key: “GCS GPS.GPS HDOP ()” type: “text”
[20180215 21:58:56.064 DEBUG] - QuickView: loading key: “GCS GPS.GPS Sats (n)” type: “text”
[20180215 21:58:56.086 DEBUG] - QuickView: loading key: “GCS Metric.Alt MSL (m)” type: “text”
[20180215 21:58:56.111 DEBUG] - QuickView: loading key: “GCS Metric.Alt REL (m)” type: “text”
[20180215 21:58:56.139 DEBUG] - QuickView: loading key: “GCS Status.Battery (%)” type: “text”
[20180215 21:58:56.201 DEBUG] - QuickView: loading key: “GCS Status.Climb (m/s)” type: “text”
[20180215 21:58:56.232 DEBUG] - QuickView: loading key: “GCS Status.Current (A)” type: “text”
[20180215 21:58:56.265 DEBUG] - QuickView: loading key: “GCS Status.Pitch (deg)” type: “text”
[20180215 21:58:56.300 DEBUG] - QuickView: loading key: “GCS Status.Roll (deg)” type: “text”
[20180215 21:58:56.340 DEBUG] - QuickView: loading key: “GCS Status.Voltage (V)” type: “text”
[20180215 21:58:56.378 DEBUG] - QuickView: loading key: “GCS Status.Yaw (deg)” type: “text”
[20180215 21:58:56.443 DEBUG] - QuickView: load settings END
[20180215 21:58:57.160 DEBUG] - qmlBaseDir “C:/Program Files (x86)/APMPlanner2”
[20180215 21:58:57.167 DEBUG] - QUrl(“file:///C:/Program Files (x86)/APMPlanner2/qml/ApmToolBar.qml”)
[20180215 21:58:57.506 DEBUG] - APMToolBar: button label SELECTED
[20180215 21:58:57.820 DEBUG] - QML Status: 1
[20180215 21:58:57.843 INFO ] - NETWORK_PROXY: Disabling System Network Proxies
[20180215 21:58:57.908 INFO ] - Screen Size is QRect(0,0 1024x600)
[20180215 21:58:59.195 WARN ] - QSettings::endGroup: No matching beginGroup()
[20180215 21:58:59.204 DEBUG] - Create Serial Connection: SerialConnection(0x2c12b40)
[20180215 21:58:59.220 INFO ] - No Ports Found ()
[20180215 21:58:59.220 INFO ] - “No Devices” 115200
[20180215 21:58:59.220 DEBUG] - APMToolBar: new Serial Link Created 1
[20180215 21:58:59.267 DEBUG] - APMToolBar setConnection: false
[20180215 21:58:59.282 DEBUG] - APMToolBar: updateLinkDisplay “No Devices” : “115200” connected: false
[20180215 21:58:59.298 INFO ] - UDP Created “UDP Link (port:14550)”
[20180215 21:58:59.298 INFO ] - UDPLink::UDP connect QHostAddress(QHostAddress::Any) : 14550
[20180215 21:58:59.984 DEBUG] - SCW: Link is disconnected
[20180215 21:59:00.015 INFO ] - No Ports Found ()
[20180215 21:59:00.015 DEBUG] - Baud rate: 115200 Expected: 4
[20180215 22:03:08.691 INFO ] - QGCCore::initialize()
[20180215 22:03:08.738 INFO ] - Current Build Info
[20180215 22:03:08.738 INFO ] - Git Hash: d9bae3ff52e8b1a656694282d76faec35c140094
[20180215 22:03:08.738 INFO ] - Git Commit: 2.0.25-rc1-31-gd9bae3ff5-DEV
[20180215 22:03:08.738 INFO ] - APPLICATION_NAME: “APM Planner”
[20180215 22:03:08.738 INFO ] - APPLICATION_VERSION: “v2.0.25”
[20180215 22:03:08.738 INFO ] - APP_PLATFORM: win
[20180215 22:03:08.738 INFO ] - APP_TYPE: stable
[20180215 22:03:19.361 INFO ] - Start Link Manager
[20180215 22:03:19.361 DEBUG] - Create MAVLinkDecoder: MAVLinkDecoder(0x29e0080)
[20180215 22:03:19.455 INFO ] - Start UAS Manager
[20180215 22:03:21.788 WARN ] - QObject::~QObject: Timers cannot be stopped from another thread
[20180215 22:03:46.237 INFO ] - QGCCore::initialize()
[20180215 22:03:46.237 INFO ] - Current Build Info
[20180215 22:03:46.237 INFO ] - Git Hash: d9bae3ff52e8b1a656694282d76faec35c140094
[20180215 22:03:46.237 INFO ] - Git Commit: 2.0.25-rc1-31-gd9bae3ff5-DEV
[20180215 22:03:46.237 INFO ] - APPLICATION_NAME: “APM Planner”
[20180215 22:03:46.237 INFO ] - APPLICATION_VERSION: “v2.0.25”
[20180215 22:03:46.237 INFO ] - APP_PLATFORM: win
[20180215 22:03:46.237 INFO ] - APP_TYPE: stable
[20180215 22:03:46.829 INFO ] - Start Link Manager
[20180215 22:03:46.829 DEBUG] - Create MAVLinkDecoder: MAVLinkDecoder(0x2a30080)
[20180215 22:03:46.845 INFO ] - Start UAS Manager
[20180215 22:03:50.212 DEBUG] - Creating MainWindow
[20180215 22:03:51.601 INFO ] - Creating SubMainWindow: SubMainWindow(0x21f8f80)
[20180215 22:03:51.602 INFO ] - setting objectName: “VIEW_MISSION”
[20180215 22:03:51.847 INFO ] - Creating SubMainWindow: SubMainWindow(0x2b3d310)
[20180215 22:03:51.848 INFO ] - setting objectName: “VIEW_FLIGHT”
[20180215 22:03:51.948 INFO ] - Creating SubMainWindow: SubMainWindow(0x2b903b0)
[20180215 22:03:51.948 INFO ] - setting objectName: “VIEW_HARDWARE_CONFIG”
[20180215 22:03:52.650 DEBUG] - fillPortsInfo
[20180215 22:03:53.047 WARN ] - libpng warning: iCCP: known incorrect sRGB profile
[20180215 22:03:53.063 WARN ] - libpng warning: iCCP: known incorrect sRGB profile
[20180215 22:03:53.082 WARN ] - libpng warning: iCCP: known incorrect sRGB profile
[20180215 22:03:54.279 INFO ] - Creating SubMainWindow: SubMainWindow(0x424b420)
[20180215 22:03:54.280 INFO ] - setting objectName: “VIEW_SOFTWARE_CONFIG”
[20180215 22:03:54.374 DEBUG] - Disable Controls
[20180215 22:03:55.367 INFO ] - Creating SubMainWindow: SubMainWindow(0x454b350)
[20180215 22:03:55.368 INFO ] - setting objectName: “VIEW_ENGINEER”
[20180215 22:03:55.432 INFO ] - Creating SubMainWindow: SubMainWindow(0x4552890)
[20180215 22:03:55.433 INFO ] - setting objectName: “VIEW_SIMULATOR”
[20180215 22:03:55.645 DEBUG] - MODE: 0
[20180215 22:03:55.705 DEBUG] - “D|PREFLIGHT”
[20180215 22:03:55.708 DEBUG] - MODE: 80
[20180215 22:03:55.713 DEBUG] - “D|STABILIZED”
[20180215 22:03:55.721 DEBUG] - MODE: 64
[20180215 22:03:55.727 DEBUG] - “D|MANUAL”
[20180215 22:03:55.734 DEBUG] - MODE: 88
[20180215 22:03:55.740 DEBUG] - “D|VECTOR|STABILIZED”
[20180215 22:03:55.746 DEBUG] - MODE: 92
[20180215 22:03:55.753 DEBUG] - “D|AUTO|STABILIZED”
[20180215 22:03:55.761 DEBUG] - MODE: 66
[20180215 22:03:55.770 DEBUG] - “D|TEST”
[20180215 22:03:56.298 DEBUG] - QUrl(“file:///C:/Program Files (x86)/APMPlanner2/qml/PrimaryFlightDisplayQML.qml”)
[20180215 22:03:57.923 DEBUG] - QML Status: 1
[20180215 22:03:57.937 DEBUG] - QUrl(“file:///C:/Program Files (x86)/APMPlanner2/qml/PrimaryFlightDisplayQML.qml”)
[20180215 22:03:58.198 DEBUG] - QML Status: 1
[20180215 22:03:58.235 INFO ] - UASActionsWidget creating UASActionsWidget(0x489d4a0)
[20180215 22:03:58.260 DEBUG] - QuickView: load settings
[20180215 22:03:58.271 DEBUG] - QuickView: loading key: “GCS GPS.GPS Fix ()” type: “text”
[20180215 22:03:58.330 DEBUG] - QuickView: loading key: “GCS GPS.GPS HDOP ()” type: “text”
[20180215 22:03:58.349 DEBUG] - QuickView: loading key: “GCS GPS.GPS Sats (n)” type: “text”
[20180215 22:03:58.370 DEBUG] - QuickView: loading key: “GCS Metric.Alt MSL (m)” type: “text”
[20180215 22:03:58.395 DEBUG] - QuickView: loading key: “GCS Metric.Alt REL (m)” type: “text”
[20180215 22:03:58.421 DEBUG] - QuickView: loading key: “GCS Status.Battery (%)” type: “text”
[20180215 22:03:58.448 DEBUG] - QuickView: loading key: “GCS Status.Climb (m/s)” type: “text”
[20180215 22:03:58.477 DEBUG] - QuickView: loading key: “GCS Status.Current (A)” type: “text”
[20180215 22:03:58.507 DEBUG] - QuickView: loading key: “GCS Status.Pitch (deg)” type: “text”
[20180215 22:03:58.541 DEBUG] - QuickView: loading key: “GCS Status.Roll (deg)” type: “text”
[20180215 22:03:58.576 DEBUG] - QuickView: loading key: “GCS Status.Voltage (V)” type: “text”
[20180215 22:03:58.612 DEBUG] - QuickView: loading key: “GCS Status.Yaw (deg)” type: “text”
[20180215 22:03:58.674 DEBUG] - QuickView: load settings END
[20180215 22:03:59.131 DEBUG] - qmlBaseDir “C:/Program Files (x86)/APMPlanner2”
[20180215 22:03:59.138 DEBUG] - QUrl(“file:///C:/Program Files (x86)/APMPlanner2/qml/ApmToolBar.qml”)
[20180215 22:03:59.350 DEBUG] - APMToolBar: button label SELECTED
[20180215 22:03:59.626 DEBUG] - QML Status: 1
[20180215 22:03:59.644 INFO ] - NETWORK_PROXY: Disabling System Network Proxies
[20180215 22:03:59.679 INFO ] - Screen Size is QRect(0,0 1024x600)
[20180215 22:04:00.767 WARN ] - QSettings::endGroup: No matching beginGroup()
[20180215 22:04:00.785 DEBUG] - Create Serial Connection: SerialConnection(0x79001b0)
[20180215 22:04:00.785 INFO ] - No Ports Found ()
[20180215 22:04:00.801 INFO ] - “No Devices” 115200
[20180215 22:04:00.801 DEBUG] - APMToolBar: new Serial Link Created 1
[20180215 22:04:00.801 DEBUG] - APMToolBar setConnection: false
[20180215 22:04:00.817 DEBUG] - APMToolBar: updateLinkDisplay “No Devices” : “115200” connected: false
[20180215 22:04:00.817 INFO ] - UDP Created “UDP Link (port:14550)”
[20180215 22:04:00.817 INFO ] - UDPLink::UDP connect QHostAddress(QHostAddress::Any) : 14550
[20180215 22:04:01.191 DEBUG] - SCW: Link is disconnected
[20180215 22:04:01.207 INFO ] - No Ports Found ()
[20180215 22:04:01.207 DEBUG] - Baud rate: 115200 Expected: 4
[20180215 22:05:05.752 INFO ] - QGCCore::initialize()
[20180215 22:05:05.752 INFO ] - Current Build Info
[20180215 22:05:05.752 INFO ] - Git Hash: d9bae3ff52e8b1a656694282d76faec35c140094
[20180215 22:05:05.752 INFO ] - Git Commit: 2.0.25-rc1-31-gd9bae3ff5-DEV
[20180215 22:05:05.752 INFO ] - APPLICATION_NAME: “APM Planner”
[20180215 22:05:05.752 INFO ] - APPLICATION_VERSION: “v2.0.25”
[20180215 22:05:05.768 INFO ] - APP_PLATFORM: win
[20180215 22:05:05.768 INFO ] - APP_TYPE: stable
[20180215 22:05:06.360 INFO ] - Start Link Manager
[20180215 22:05:06.360 DEBUG] - Create MAVLinkDecoder: MAVLinkDecoder(0x29b0080)
[20180215 22:05:06.376 INFO ] - Start UAS Manager
[20180215 22:05:07.170 DEBUG] - Creating MainWindow
[20180215 22:05:08.020 INFO ] - Creating SubMainWindow: SubMainWindow(0x20d6440)
[20180215 22:05:08.020 INFO ] - setting objectName: “VIEW_MISSION”
[20180215 22:05:08.189 INFO ] - Creating SubMainWindow: SubMainWindow(0x2ac12c0)
[20180215 22:05:08.190 INFO ] - setting objectName: “VIEW_FLIGHT”
[20180215 22:05:08.287 INFO ] - Creating SubMainWindow: SubMainWindow(0x2b10900)
[20180215 22:05:08.288 INFO ] - setting objectName: “VIEW_HARDWARE_CONFIG”
[20180215 22:05:08.982 DEBUG] - fillPortsInfo
[20180215 22:05:09.340 WARN ] - libpng warning: iCCP: known incorrect sRGB profile
[20180215 22:05:09.361 WARN ] - libpng warning: iCCP: known incorrect sRGB profile
[20180215 22:05:09.382 WARN ] - libpng warning: iCCP: known incorrect sRGB profile
[20180215 22:05:10.574 INFO ] - Creating SubMainWindow: SubMainWindow(0x44580b0)
[20180215 22:05:10.579 INFO ] - setting objectName: “VIEW_SOFTWARE_CONFIG”
[20180215 22:05:10.675 DEBUG] - Disable Controls
[20180215 22:05:11.582 INFO ] - Creating SubMainWindow: SubMainWindow(0x47496b0)
[20180215 22:05:11.587 INFO ] - setting objectName: “VIEW_ENGINEER”
[20180215 22:05:11.655 INFO ] - Creating SubMainWindow: SubMainWindow(0x4750c30)
[20180215 22:05:11.660 INFO ] - setting objectName: “VIEW_SIMULATOR”
[20180215 22:05:11.888 DEBUG] - MODE: 0
[20180215 22:05:11.948 DEBUG] - “D|PREFLIGHT”
[20180215 22:05:11.953 DEBUG] - MODE: 80
[20180215 22:05:11.957 DEBUG] - “D|STABILIZED”
[20180215 22:05:11.962 DEBUG] - MODE: 64
[20180215 22:05:11.967 DEBUG] - “D|MANUAL”
[20180215 22:05:11.972 DEBUG] - MODE: 88
[20180215 22:05:11.977 DEBUG] - “D|VECTOR|STABILIZED”
[20180215 22:05:11.983 DEBUG] - MODE: 92
[20180215 22:05:11.988 DEBUG] - “D|AUTO|STABILIZED”
[20180215 22:05:11.993 DEBUG] - MODE: 66
[20180215 22:05:11.998 DEBUG] - “D|TEST”
[20180215 22:05:12.640 DEBUG] - QUrl(“file:///C:/Program Files (x86)/APMPlanner2/qml/PrimaryFlightDisplayQML.qml”)
[20180215 22:05:13.333 DEBUG] - QML Status: 1
[20180215 22:05:13.410 DEBUG] - QUrl(“file:///C:/Program Files (x86)/APMPlanner2/qml/PrimaryFlightDisplayQML.qml”)
[20180215 22:05:13.795 DEBUG] - QML Status: 1
[20180215 22:05:13.994 INFO ] - UASActionsWidget creating UASActionsWidget(0x2abd5c0)
[20180215 22:05:14.012 DEBUG] - QuickView: load settings
[20180215 22:05:14.017 DEBUG] - QuickView: loading key: “GCS GPS.GPS Fix ()” type: “text”
[20180215 22:05:14.076 DEBUG] - QuickView: loading key: “GCS GPS.GPS HDOP ()” type: “text”
[20180215 22:05:14.088 DEBUG] - QuickView: loading key: “GCS GPS.GPS Sats (n)” type: “text”
[20180215 22:05:14.103 DEBUG] - QuickView: loading key: “GCS Metric.Alt MSL (m)” type: “text”
[20180215 22:05:14.119 DEBUG] - QuickView: loading key: “GCS Metric.Alt REL (m)” type: “text”
[20180215 22:05:14.137 DEBUG] - QuickView: loading key: “GCS Status.Battery (%)” type: “text”
[20180215 22:05:14.157 DEBUG] - QuickView: loading key: “GCS Status.Climb (m/s)” type: “text”
[20180215 22:05:14.189 DEBUG] - QuickView: loading key: “GCS Status.Current (A)” type: “text”
[20180215 22:05:14.220 DEBUG] - QuickView: loading key: “GCS Status.Pitch (deg)” type: “text”
[20180215 22:05:14.253 DEBUG] - QuickView: loading key: “GCS Status.Roll (deg)” type: “text”
[20180215 22:05:14.288 DEBUG] - QuickView: loading key: “GCS Status.Voltage (V)” type: “text”
[20180215 22:05:14.335 DEBUG] - QuickView: loading key: “GCS Status.Yaw (deg)” type: “text”
[20180215 22:05:14.398 DEBUG] - QuickView: load settings END
[20180215 22:05:14.809 DEBUG] - qmlBaseDir “C:/Program Files (x86)/APMPlanner2”
[20180215 22:05:14.815 DEBUG] - QUrl(“file:///C:/Program Files (x86)/APMPlanner2/qml/ApmToolBar.qml”)
[20180215 22:05:14.963 DEBUG] - APMToolBar: button label SELECTED
[20180215 22:05:15.064 DEBUG] - QML Status: 1
[20180215 22:05:15.083 INFO ] - NETWORK_PROXY: Disabling System Network Proxies
[20180215 22:05:15.117 INFO ] - Screen Size is QRect(0,0 1024x600)
[20180215 22:05:16.219 WARN ] - QSettings::endGroup: No matching beginGroup()
[20180215 22:05:16.228 DEBUG] - Create Serial Connection: SerialConnection(0x2175710)
[20180215 22:05:16.243 INFO ] - No Ports Found ()
[20180215 22:05:16.243 INFO ] - “No Devices” 115200
[20180215 22:05:16.259 DEBUG] - APMToolBar: new Serial Link Created 1
[20180215 22:05:16.259 DEBUG] - APMToolBar setConnection: false
[20180215 22:05:16.259 DEBUG] - APMToolBar: updateLinkDisplay “No Devices” : “115200” connected: false
[20180215 22:05:16.275 INFO ] - UDP Created “UDP Link (port:14550)”
[20180215 22:05:16.275 INFO ] - UDPLink::UDP connect QHostAddress(QHostAddress::Any) : 14550
[20180215 22:05:16.649 DEBUG] - SCW: Link is disconnected
[20180215 22:05:16.665 INFO ] - No Ports Found ()
[20180215 22:05:16.665 DEBUG] - Baud rate: 115200 Expected: 4
Seems to something in the serial subsystem - I will have a look at the weekend - perhaps we can find it. @Mcquack does yous system have a serial port - a real one or only USB?
Ok I tried to reproduce - but failed it is definitely not the serial subsystem.
So I did some googeling and found this https://bugreports.qt.io/browse/QTBUG-40991 and this https://bugreports.qt.io/browse/QTBUG-42240. It is somehow related to intel graphics and some Qt versions. Seems like the only solution is to update the Qt version to 5.5.0 or 5.6.3.
Thanks Arne.
I’ll update to 5.6.3 and create a new Windows installer and @Mcquack can try that.
@Mcquack Please download and try this installer. It was built with Qt 5.6.3:
this is the new one.
[20180217 20:20:56.563 INFO ] - QGCCore::initialize()
[20180217 20:20:56.563 INFO ] - Current Build Info
[20180217 20:20:56.563 INFO ] - Git Hash: 1dd5e8051e21c182e49633cb9ada56dc687c83c2
[20180217 20:20:56.563 INFO ] - Git Commit: 2.0.25-37-g1dd5e8051-DEV
[20180217 20:20:56.563 INFO ] - APPLICATION_NAME: “APM Planner”
[20180217 20:20:56.563 INFO ] - APPLICATION_VERSION: “v2.0.25”
[20180217 20:20:56.563 INFO ] - APP_PLATFORM: win
[20180217 20:20:56.563 INFO ] - APP_TYPE: stable
[20180217 20:21:00.619 INFO ] - Start Link Manager
[20180217 20:21:00.619 DEBUG] - Create MAVLinkDecoder: MAVLinkDecoder(0x2890080)
[20180217 20:21:00.697 INFO ] - Start UAS Manager
[20180217 20:21:05.833 DEBUG] - Creating MainWindow
[20180217 20:21:07.222 INFO ] - Creating SubMainWindow: SubMainWindow(0x20deac0)
[20180217 20:21:07.223 INFO ] - setting objectName: “VIEW_MISSION”
[20180217 20:21:07.480 INFO ] - Creating SubMainWindow: SubMainWindow(0x29c5230)
[20180217 20:21:07.481 INFO ] - setting objectName: “VIEW_FLIGHT”
[20180217 20:21:07.584 INFO ] - Creating SubMainWindow: SubMainWindow(0x2a1fbb0)
[20180217 20:21:07.585 INFO ] - setting objectName: “VIEW_HARDWARE_CONFIG”
[20180217 20:21:08.308 DEBUG] - fillPortsInfo
[20180217 20:21:08.727 WARN ] - libpng warning: iCCP: known incorrect sRGB profile
[20180217 20:21:08.750 WARN ] - libpng warning: iCCP: known incorrect sRGB profile
[20180217 20:21:08.772 WARN ] - libpng warning: iCCP: known incorrect sRGB profile
[20180217 20:21:10.109 INFO ] - Creating SubMainWindow: SubMainWindow(0x41c2090)
[20180217 20:21:10.114 INFO ] - setting objectName: “VIEW_SOFTWARE_CONFIG”
[20180217 20:21:10.234 DEBUG] - Disable Controls
[20180217 20:21:11.595 INFO ] - Creating SubMainWindow: SubMainWindow(0x44dd960)
[20180217 20:21:11.601 INFO ] - setting objectName: “VIEW_ENGINEER”
[20180217 20:21:11.680 INFO ] - Creating SubMainWindow: SubMainWindow(0x44e6420)
[20180217 20:21:11.683 INFO ] - setting objectName: “VIEW_SIMULATOR”
[20180217 20:21:11.953 DEBUG] - MODE: 0
[20180217 20:21:12.016 DEBUG] - “D|PREFLIGHT”
[20180217 20:21:12.020 DEBUG] - MODE: 80
[20180217 20:21:12.025 DEBUG] - “D|STABILIZED”
[20180217 20:21:12.030 DEBUG] - MODE: 64
[20180217 20:21:12.036 DEBUG] - “D|MANUAL”
[20180217 20:21:12.040 DEBUG] - MODE: 88
[20180217 20:21:12.045 DEBUG] - “D|VECTOR|STABILIZED”
[20180217 20:21:12.049 DEBUG] - MODE: 92
[20180217 20:21:12.057 DEBUG] - “D|AUTO|STABILIZED”
[20180217 20:21:12.062 DEBUG] - MODE: 66
[20180217 20:21:12.066 DEBUG] - “D|TEST”
[20180217 20:21:12.621 DEBUG] - QUrl(“file:///C:/Program Files (x86)/APMPlanner2/qml/PrimaryFlightDisplayQML.qml”)
[20180217 20:21:15.993 ERROR] - Failed to load opengl32sw.dll (No se puede encontrar el modulo especificado.)
[20180217 20:21:16.003 WARN ] - Failed to load and resolve WGL/OpenGL functions
[20180217 20:21:16.043 ERROR] - Failed to load opengl32sw.dll (No se puede encontrar el modulo especificado.)
[20180217 20:21:16.050 WARN ] - Failed to load and resolve WGL/OpenGL functions
[20180217 20:21:17.061 DEBUG] - QML Status: QQuickView::Status(Ready)
[20180217 20:21:17.076 DEBUG] - QUrl(“file:///C:/Program Files (x86)/APMPlanner2/qml/PrimaryFlightDisplayQML.qml”)
[20180217 20:21:17.380 DEBUG] - QML Status: QQuickView::Status(Ready)
[20180217 20:21:17.418 INFO ] - UASActionsWidget creating UASActionsWidget(0x47fcdd0)
[20180217 20:21:17.443 DEBUG] - QuickView: load settings
[20180217 20:21:17.450 DEBUG] - QuickView: loading key: “GCS GPS.GPS Fix ()” type: “text”
[20180217 20:21:17.483 DEBUG] - QuickView: loading key: “GCS GPS.GPS HDOP ()” type: “text”
[20180217 20:21:17.500 DEBUG] - QuickView: loading key: “GCS GPS.GPS Sats (n)” type: “text”
[20180217 20:21:17.520 DEBUG] - QuickView: loading key: “GCS Metric.Alt MSL (m)” type: “text”
[20180217 20:21:17.542 DEBUG] - QuickView: loading key: “GCS Metric.Alt REL (m)” type: “text”
[20180217 20:21:17.565 DEBUG] - QuickView: loading key: “GCS Status.Battery (%)” type: “text”
[20180217 20:21:17.595 DEBUG] - QuickView: loading key: “GCS Status.Climb (m/s)” type: “text”
[20180217 20:21:17.622 DEBUG] - QuickView: loading key: “GCS Status.Current (A)” type: “text”
[20180217 20:21:17.652 DEBUG] - QuickView: loading key: “GCS Status.Pitch (deg)” type: “text”
[20180217 20:21:17.689 DEBUG] - QuickView: loading key: “GCS Status.Roll (deg)” type: “text”
[20180217 20:21:17.730 DEBUG] - QuickView: loading key: “GCS Status.Voltage (V)” type: “text”
[20180217 20:21:17.764 DEBUG] - QuickView: loading key: “GCS Status.Yaw (deg)” type: “text”
[20180217 20:21:17.831 DEBUG] - QuickView: load settings END
[20180217 20:21:18.332 DEBUG] - qmlBaseDir “C:/Program Files (x86)/APMPlanner2”
[20180217 20:21:18.337 DEBUG] - QUrl(“file:///C:/Program Files (x86)/APMPlanner2/qml/ApmToolBar.qml”)
[20180217 20:21:18.546 DEBUG] - APMToolBar: button label SELECTED
[20180217 20:21:18.956 DEBUG] - QML Status: QQuickView::Status(Ready)
[20180217 20:21:18.971 INFO ] - NETWORK_PROXY: Disabling System Network Proxies
[20180217 20:21:19.007 INFO ] - Screen Size is QRect(0,0 1024x600)
[20180217 20:21:20.100 ERROR] - Failed to load opengl32sw.dll (No se puede encontrar el modulo especificado.)
[20180217 20:21:20.106 WARN ] - Failed to load and resolve WGL/OpenGL functions
[20180217 20:21:20.146 ERROR] - Failed to load opengl32sw.dll (No se puede encontrar el modulo especificado.)
[20180217 20:21:20.153 WARN ] - Failed to load and resolve WGL/OpenGL functions
[20180217 20:21:20.160 FATAL] - Failed to create OpenGL context for format QSurfaceFormat(version 2.0, options QFlags(), depthBufferSize 24, redBufferSize -1, greenBufferSize -1, blueBufferSize -1, alphaBufferSize -1, stencilBufferSize 8, samples 16, swapBehavior 2, swapInterval 1, profile 0) .
This is most likely caused by not having the necessary graphics drivers installed.
Install a driver providing OpenGL 2.0 or higher, or, if this is not possible, make sure the ANGLE Open GL ES 2.0 emulation libraries (libEGL.dll, libGLESv2.dll and d3dcompiler_*.dll) are available in the application executable’s directory or in a location listed in PATH.
[20180217 20:21:20.223 DEBUG] - Destroy MAVLinkDecoder: MAVLinkDecoder(0x2890080)
Unfortunately it looks like your graphics card does not support OpenGL 2.0 which is required by APM Planner 2.
Ohhhh It’s a pity . I 'd like this computer because is small , but it’s ok.
Thank you very much for your help and Arne-WArne Wischmann you too.
Really thanks guys
