OS: Kubuntu 15.04 (Vivid Vervet)
Apmplanner2 version: 2.0.18 and also tested with the master git branch with the same results
Problem: Unable to open logs, when I click to “Open Log” the program hangs and doesn’t open the file dialog.
The console shows:
kf5.kservice.sycoca: Trying to open ksycoca from "/home/user/.cache/ksycoca5"
and nothing more.
Also in order to start the program I must add the parameter -style=fusion.
I don’t think there is much I can do, as this seems like a Qt on Kubuntu issue. I can spin up a Kubuntu VM to check. Try Qt5.4.2 to see if that fixes the issue?
