Hello I’m having problems with the latest versions of APM fimeware using several different gps the same thing happens even changing several apm
When I put mode stabilize everything is correct without strangers.
Once switched to Loiter mode the Dron has many faults
1 the dron begins to descend and ascend alone
2 the dron begins to be very very unstable not able to be still
3 rtl is sometimes if it does well and others do not
E calibrated many apm never happened this, now if and not already because I use apm 2.8 and I use gps from 6m to 8m calibrated in many ways all the calibrations are correct everything is checked correctly.
This only happens with Loiter or Rtl
