I am in need of some guidance how to approach/ fix a connection resp. forwarding issue.
Situation
I have a working vehicle connection from SITL (or Pixhawk hardware) to Mission Planner (v. 1.3.62), running on a laptop, via tcp.
Now I am trying to add and connect a (Windows) tablet into the system, which is also running Mission Planner (same version).
Desired setup
For this, I want to forward MAVLink packets out from Mission Planner (laptop) to Mission Planner (tablet), by using SerialOutput - MAVLink.
What works
I can successfully connect via the MP instance on the laptop - but only as long as this is done via tcp (and the tablet is on the same wifi network as the laptop).
What does not work
In the field though, I need this to work via a 3DR radio modem.
However, when trying to forward MAVLink via the COM port of the radio modem connected to the laptop (at the appropriate baud rate, with write access permitted), I am unable to connect to this link from Mission Planner (tablet).
(The SerialOutput (from the laptop) seems active as such; the radios seem correctly configured (green LED is on) and are happily blinking orange when trying to connect.)
On trying to connect MP via the radio modem on the tablet: “Error - No Heartbeat Packets Received”
If I am not mistaken, this connection approach should be possible as such. What must be done to get a successful connection?
Thanks in advance for your inputs!
