Hi, I’ve recently encountered a problem whilst using Mission planner 1.3.57. The problem is that when I create a WayPoint file in my flight polygon the estimated time at the bottom does not match the time it takes when I do the UAV flight on site. I am flying using an XR6 drone and this problem has only occurred recently. This is causing me problems because of my battery life. I try to fly around 10 minutes so for example mission planner could tell me the flight is 9 minutes but in reality the actual flight takes 11 minutes
