I have a problem with scripted Aerobatics on a Pixhawk 6C Mini.
Used Firmware is ArduPlane V4.4.0-beta3.
The Lua-Script plane_aerobatics.lua is loaded an the parameters are visible and working on the controler.
The settings are done according to the manual and the video.
I have selected and startet Trick 2 (Immelmann Fast) It is working and gets finished. Then I load the Trick “Super Air Show” and get the message "LUA: /APM/scripts/plane_aerobatics.lua:3013:attem.
I need informations regarding this error what it means.
If I run it on SITL and RealFlight it works fine.
Thanks and best regards, Markus
