I can connect from the Mission Planner only when battery is plugged in, few seconds before Strom32 is initialized. Then it is not possible connect anymore. The red LED on the telemetry module on the pixhawk side is blinking even if I’am not connected from the Mission Planner. I can reconnect only when I unplug serial connector from the Storm32 unit. I tried connect Storm32 to the others serial ports, same behavior.
