Problem with configuring APM and absolut unstable Loiter
Hi i´m new with APM and i have big Problems to calibrate APM
in Stable Mode or Alt Hold the copter is absolut perfect to fly.
but in all other GPS Modes…like Loiter it fly like “drunken Elephant”
what i didn´t understand…why my IMU and MAG is everey failed.
I have now Reset APM to default…and complete new installed…but in the new Log (not flying this time) it shows me Errors
[quote]Log File C:/Program Files (x86)/Mission Planner/logs/2015-03-09 12-44-01.log
Size (kb) 81.6015625
No of lines 2290
Duration 0:15:17
Vehicletype ArduCopter
Firmware Version V3.1.5
Firmware Hash 3c57e771
Hardware Type APM 2
Free Mem 1202
Skipped Lines 0
Test: Balance/Twist = GOOD -
Test: Brownout = GOOD -
[color=#FF0000]Test: Compass = GOOD - No MAG data, unable to test mag_field interference[/color]
Test: Dupe Log Data = GOOD -
Test: Empty = GOOD -
Test: Event/Failsafe = FAIL - ERR found: GPS_GLITCH
Test: GPS = FAIL - GPS glitch errors found (8)
Min satellites: 6, Max HDop: 16.83
[color=#BF0000]Test: IMU Mismatch = UNKNOWN - No IMU log data[/color]
Test: Parameters = GOOD -
Test: PM = GOOD -
Test: Pitch/Roll = GOOD -
Test: Thrust = GOOD -
Test: VCC = GOOD - [/quote]
what to hell is wrong?
please help…before i throw it in garbage
APM is an under powered flight controller and logging is set low. You need to set logging higher so that there is information that can be analyzed.
copter.ardupilot.com/wiki/config … og_bitmask
Yours is set to 894 and needs to be like NearlyAll 45054.
Then run the test on the log and you will get more information.
Set the logging back when everything looks good.
Mike
thanks…
the last days i have do all clear…downgrade to older FW…and do complete new calibrate…
i load Frame Config for “Camera Plattform”…and do yesterday testflight.
yesterday it was looking good in flight…but i dump has forgete to prgramm “Autotune” to Channel7…lol
littlebit shaggy…but flyable.
this is now my config
facebook.com/photo.php?fbid … 028&type=1
and here the vids from yesterday
[youtube]https://www.youtube.com/watch?v=ir2InOz217[/youtube]
[youtube]https://www.youtube.com/watch?v=rXQeDf7msyU[/youtube]
